Old setup:-
E6400 @ 3.6ghz 1.55v
8800GTS 690/1000
EK 8800GTS block
Fuzion V1
Thermochill 120.3 rad w/YSTech 120mmx38 fans - 135cfm and not quiet
DDC Ultra & Bayres
1/2 ID tubing & barb fittings.
I've recently updated the hardware after 4 years of duty without even emptying the water loop; I just removed the 8800GTS block and topped up the res. Running a 2500k @ 4843mhz 1.44v which hits max 63deg on core2.
I've got some new stuff to fit into my WC loop - EK 580 DCII block for my Asus GTX570, an XSPC DDC Bayres to simplify my loop a bit, a load of 3/8 compression fittings and 3/8 tubing. While I'm spending money I don't have
I was considering upgrading to the EK Supreme HF.
The rad is cool to the touch at this OC at the moment even when priming - I'm definitely at the thermal transfer limit of the water block. Will the Supreme HF be too restrictive to run my GPU too? Looking at reviews of the Fuzion V2 I know the Supreme HF is probably even more restrictive. Worth me spending £50 for a 2-3deg drop dya think?
8800GTS 690/1000
EK 8800GTS block
Fuzion V1
DDC Ultra & Bayres
