Hi
the kids (ancient) pc has finally bitten the dust - not worth the time and hassle to try to resurrect it.
I have some spare components lying around
- E6750, 2GB DDR2 x 800HZ, Samsung disk, LG CD/DVD drive, keyboard and mouse.
I am wondering about the option of building a replacement with these.
I would very much appreciate advice on
- motherboard, with at least 2 sata, at least 6 usb, onboard sound, ideally on-board wireless, ideally either external eSata or firewire
- graphics card, decent one but certainly not high-cost/top of the range
- case, basic one, with good cooling - looks not of prime importance
- power supply, probably 450-500W
I have looked at various components on various websites but I dont know which parts are the ones to get and which are the ones to avoid.
The pc is used for browsing, email, school projects, some wp / spreadsheets, and SOME light gaming.
Cost is important.
I tend to have limited choice from the local sources, so if parts are from UK source it has to be one which ships to Ireland.
A Good fit will suffice - I am not looking for the perfect system.
I have got very good advice here previously so hopefully I will again this time.
Thanks in advance
nomadic
Cost is important.
Thanks in advance
nomadic
