Replace my ageing Dell 2650
4 Feb 2009
Hi all,
I'm new to this forum, so hello.
My question.
I have had my server at home in my shed for probably over 3 > 4 years now and I'm looking at replacing it for several reasons.
It's a Dell 2650, dual xeon with 8gb ram, raid 5 with 5 scsi disks, running VMware ESX.
I want to replace it because it's getting old now and i'm worried about it's reliability and also because it's very power hungry. I would also like to have a 64bit os to run things like Exchange 2007 and suchlike.
It's been a long time since I have built my own pc and i'm very out of touch, so i'm after some advice. My remit is that it needs to have least 8gb ram upgradable to 16gb when I get the cash and a quad core processor. It also needs to be as power efficient as a server thats on all the time can be. My current 2650 is using about 400 > 500 watts running.
Coincidently, this months copy of PC Pro does a motherboard / cpu / memory and case comparison which I have read to try and understand.
My short list is currently;
Intel Core 2 Quad Q8200
Asus P5Q Pro
AMD Phenon II x4 920
Asus M3N78 Pro
As for the case, i have no idea, I have seem a few servers ones which I guess have more fans in. I will also be getting two 1tb drives for storage.
Any help / advise will be greatfully recieved.
Regards
Gareth
Massive overkill, massive electricity bills. Been there, done that :D
I initially went to a q6600 with 8gb ram on an intel matx board but have recently changed to the fantastic ml110g5, bought for £180 when they had the deal on. Now with 8gb of ram it runs esxi and 15+ virtual machines very well indeed. Power usage is 95 watts.
The quad was overpowered for ne so the 2.4ghz dual is more than enough, and even with that amount of machines running the host is only using about 6gb of ram.
Though if you decide you really need 16gig of ram then you will need to look for alternatives.
Slightly O/T, Your running 15+ VM's with the dual core chip it comes with?
Hi guys,
Yes, it is a bit of a beast, I did have two actually. I aquired them from work and at the time, they were the only really option for a server, but, times change. I've had all the jokes from work collegues ;-)
It's in a shed cos of the noise and size but I want to use the shed for other stuff, so, i'd like to move my server to the house.
The P5Q will take 16bg, but, do to cost of the dimms, 8gb will be fine for me to start with.
Any ideas on the best case, I was looking at the Antec Atlas one?
Also, AMD .vs. Intel. currently leaning towards Intel cos it's more widespread.
thanks
It depends on how many drives, cooling etc.. I have the 1st gen coolermaster stacker as a server case at home, can hold loads of hdd's and plenty of cooling.
Yes.
The point I'm was trying to make is that a monster server at home is totally unnecessary (depending on your usage of course & whether you are happy paying for the electricity & listening to it roaring away). My quartly bill HALVED after getting rid of all my old junk & virtualizing all my main servers.
