What problems are you having with this router? Reviews say it's pretty good?
Good range and AC wireless to boot.
I say this as I'm looking to get the BT fibre 76 package.
Without wishing to speak for the OP I thought I'd answer since I've just ditched my homehub 5 in favour of a modem/router combo. Your take on this may be different as a potential BT customer (I'm with Plusnet) but the thing that made me swap out the HH5 were the built in intrusion features planted by BT (and impossible to remove currently).
Looking at my router logs for the last few months the I see regular activity by BTs remote agent (sometimes up to 10 events a day). Now not knowing what exactly these events are for you might think 'why care?' but the other issue is that a proportion of these remote accesses culminate in a router reboot and, given BTs DLM policy (and my reducing downstream connection speed) I can't help but feel that it's BT and not any inherent line stability issues that are reducing my speed.
That was enough to make me decide to get rid and go for a hacked modem and separate router - it is a shame though because, as you've pointed out, as far as performance and features go the HH5 is a decent bit of kit. Pity but there you have it...
I assume you mean BT Agent which as far as I know is just an implementation of TR-069. Even some third party routers have TR-069 support (pretty sure a lot of Netgears do, hence why ISPs used to give them out).
I don't know why people are suddenly fussed about BT Agent on VDSL when cable ISPs (C&W, Blue Yonder, NTL, Virgin, etc) have had the same access to your modem for decades and nobody cared.
BT's reasoning is most likely to be able to perform remote troubleshooting and to deploy new features as they become available (e.g. all the disabled IPv6 stuff in the HH5, and presumably 30a and vectoring in the future).
Sure, things like automatic firmware updates are pretty scary and could be very annoying on more advanced routes. I just don't understand the sudden paranoia around the net about this old feature.
EDIT: Just to clarify, I do think that stuff like TR-069 can be a problem and a lot of the recent router backdoor exploits (D-Link last year, Netgear this year) sound like badly implemented TR-069 responding to remote IPs instead of just internal IPs. But framing it as "BT spying" or "BT intrusion" isn't accurate.
In terms of framing things I think you'll find you're on your own with the 'BT spying' one but hey artistic license n all that eh![]()
- No customisable DNS (and BT's servers don't for example resolve CNAMEs to local IPs which is a problem for development servers).
- Some annoying DNS intercept error pages (e.g. troubleshooting page when net is down, parental controls page when you first connect a mobile device to Wifi).
- Half implemented NAT loopback.
- Virtually no port forwarding options.
- No way to limit access to ports by remote IP.
- No QoS at all, so you can't even for example give a VOIP phone's IP high priority.
- And so on.
It depends how you use the internet really and how much you need to configure your router. If the most you ever do is forward ports for games then the HH5 should be almost good enough.
WiFi is decent though. Not so much the range or anything but a common problem I have with other routers is that they can't sustain high bandwidth duplex WiFi traffic for long periods without crashing, which the HH5 seems good at presumably because it needs to be for BT Sport, Youview, etc.
I'm going to live with the HH5 for 6 months or so until there's a good router with built in VDSL, 802.11ac and customisable firmware. I can't be bothered with bridging crap these days as you do lose line stats etc.
thanks for the reply.
Is it possible to put the HH5 in modem mode and use my own router if needed?
