Replace original case fans?
Caporegime
1 Mar 2008
I've got a NZXT Lexa Blackline which has two red LED 120mm case fans. I also have two Akasa 120mm red LED fans. Would the Akasa fans be better than the NZXT ones? Don't know the specs of the NZXT fans but the Akasa's are as follows:
Dimensions: 120x120x25mm
Bearing: Sleeve
Speed: 1700 RPM
Voltage: 12VDC
Current: 0.18a
Airflow: 56 CFM
Noise Level: 29.74 dB(A)
Never trust the specs that the companies give you, they're always biased to show their fans in the best light.
Naud
I replaced the fans that came with my Stacker case with Akasas' and they were much quieter and caused less vibration.
