replace r9 280
4 Mar 2015
Brighton
hi I need some advise on a card replacement my 280 has failed, i'm looking at
a 960 or a 380 can't really go above 200.
running an i5 3.2 750w psu 16 gb
Many Thanks
Get a used 290X, significantly better than a 960 or 380. Even a 290 is much better, with the triple fan Powercolor and Saphire Tri-X/Vapor X being the best non reference coolers.
Its only been out a little over a year. How long was the warranty? what brand?
Used 290. Or used GTX 970 if you can find one for £200, or a GTX 780.
