- 5 May 2004
Hi guys my sky hub is not great to be honest and struggles with multiple connections and also the 5ghz wifi range is not great.
Im on the sky fibre max pack and get around 78mg download and 19 up
Is there a direct replacement rhat would be plug and play basically which would be better and give better range also and help with multiple devices .
Dont really want to go the adding another router to the existing sky one
Thanks
Thanks
