I recently bought a second 7950 to go with my original one as it was a reasonably cheap way of upgrading. However after only a few weeks I am sick to death of blooming xfire and the faffing about I have to do in order to get any performance gains out of it so am thinking of getting rid of these cards and replacing them with a single 970.
The only demanding games I play are BF4 and Rome 2 TW and I've spent more time configuring than actually playing these over the past few weeks. My fps in BF4 range from 20-80 at random (sometimes 80ish all game and sometimes 20ish and sometimes in between) and I can't seem to work out what is causing the issues- new patch hasn't helped, mantle doesn't change much and I can't find any reasons why there is so much variance.
I've only just started configuring RTW2 for a playthrough and after hours of changing settings and messing about I've discovered that the benchmark actually runs 10fps faster (at a huge 30fps) with xfire turned off! So I've reached the end of my tether. Searching on the net seems to suggest that RTW has had issues with xfire since release and if it's not fixed now I doubt it will be. Argh!
So I'm probably going to throw the damn cards in the bin and buy a new single GPU which will be faster, cooler and quieter.
Unless anyone can suggest a magic fix of course?
My specs are as follows:
850W PSU
2600K not Oc'd (I know this may be a bottleneck but I should still be able to get better fps in both games and I will be ocing to about 4gHz)
16Gb RAM
Various SSD HDD
Am I best off going for the 970 and rebuilding or a 290, could I use the 290 with one of my 7950s in xfire at the risk to my sanity?
850W PSU
16Gb RAM
Various SSD HDD
I have a new MB though so maybe that will make a bit of a difference.
