8 Sep 2011 at 09:27 #1 ukgeezer1 ukgeezer1 Associate Joined 5 Nov 2010 Posts 118 Hi my new rig is a 2500k, asrock z68 ex4gen3, fractal r3, gfx undecided. I am currently using my Zalman CNPS9700 NT. is it worth replacing it? I am after a very quiet PC. in the r3 i am using stock fans only. thanks
8 Sep 2011 at 14:34 #2 AgedIdiot AgedIdiot Soldato Joined 31 Oct 2007 Posts 2,601 Location Gods County(Allegedly) ukgeezer1 said: I am currently using my Zalman CNPS9700 NT. is it worth replacing it? Click to expand... Probably not - spec. says it should work with the socket( tho' paring such with your actual m-board ?) and from what I've read it's a decent cooler. Give it a go - you can always buy a new cooler if it does not do the job that you want
8 Sep 2011 at 14:45 #3 ukgeezer1 ukgeezer1 Associate OP Joined 5 Nov 2010 Posts 118 I have it installed, I just don't know whether it is noiser than current models at load.
