Replaced entire pc components, still having issues.
Got my legal copy of windows 7 home upgraded to 10, its an OEM but tahts fine.
Did this issue start after upgrading to 10 or before? Maybe compatibility issues with the pad software/drivers if started after the upgrade, maybe check for updated drivers from manufacturers website?
Have you tried a different connection like dvi/hdmi ect with the benq monitor or is that Gsync also ?
The BenQ is non gsync, the 2720t. It uses Dual Link DVI, but it happens on that one too.
The gsync acer is display port only (but i think all gsync is)
But i ruled out monitors and displays as ive tried on my hd tv and my friends screen and its all the same.
The issue persisted on windows 7, and carried onto windows 10, however i might stick with windows 7 when i reinstall and do tests that way.
I had this problem, can't remember exactly what I used to fix it, but it was some form of driver from Intel for ssd drives. Had it for months until I found a fix about 30 pages into a Google search.
I did end up with the Intel drive programme installed as well, so maybe the drivers installed with that.
Sorry can't be more help, on mobile just now.
If you do find it please let me know! I hope it will help my situation!
'I play pad.
and i've replaced the pad, and it didnt help, and the problem doesnt happen on any other rigs using the same pad. '
but does it do it without the 'pad (what sort?)'
Wanted to give an update.
Reinstalled Windows, the worst of it has gone, its still there but not as glaringly bad. Sometimes it is sometimes it isnt.
I've tried plugging in each graphics card to test and no dice, using the onboard is impossible to get enough framerates.
I have a new PSU coming, this time a platinum as opposed to a bronze, see if that helps a bit (I did need more wattage) and if not i'll look into the RAM because i dont see how it can be anything else (As the harddrives are fine)
'I play pad.
Happens with any mouse too.
I'm sorry to hear about your problem, it really sucks having such persistent issues.
To me it does sound like some sort of driver issue.
nvidia experience i think its called, has this been disabled/switched off,
what audio drivers are loaded, may be a conflict between onboard and nvidia's
I dont use gsync as it's a bit useless to me. (It isnt a bad thing, but i personally dont game much on it anymore and have my pc go into my 50" tv when i wanna relax on the sofa and play (And no thats not the cause i tested it on all monitors :P))
I have tried the 680 in this rig and the issue persists, and individually tested both 970s in the second rig together and one by one adn they dont have an issue in it.
I've tried hdmi and dvi like i said on the second monitor and only displayport on the main monitor.
I dont use nvidia experience.
I have pretty much decided to gut and sell all the interior of this, as i have tried every piece individually and none show any faults testing in the second rig or in any form of benchmarking tests and stress tests. and i'm going to keep my new Power Supply (whic didnt fix the issuem 760w platinum corsair) and the two 970s and do a completely new rig. and if the issue persists with that then i dont know and i'll replace the 970s i guess.
Although i still dont have access to the trading forum
(ps throw on a windows 10 oem on top of that so i can utilize the full 32gb RAM)
But i will probably do this when i move into my new flat because i actually recently got kicked out due to family drama. Planning on moving up north to Preston due to cheapness.
