Replacement cables for modular PSU
7 Aug 2017
Oxford
Lost one of the PCI-e cables (8pin) from my Enermax Modu and need it for the new GPU. Got around by using a 2*molex to 8pin adapter as a temp measure. Is there a site where you can find replacement cables?
There are some replacement cables on the OC site however you may be best to send them a message directly and would be able to tell you if they have something that would work.
I think the part number you want is EMC014-F seems there’s a lot of European shops selling them
I could make the cable, do you have a link with pin allocation?
Sorry no as on my phone and useless on that
But since you already have 1 pci~e cable
Surely it's just a case of copying the pin out of that one?
Though may involve pulling back heatshrink and sleeving but can put it back afterwards
Edit am suffering 15 post limit problem so if don't reply again for a while that's why
Edited hopefully you noticed it
Hit with the 15 post limit again
Keep checking if I add edits to your reply as can't post yet again
my corsair if looking down on it with latch on top and pin holes facing away from me~ie like it goes into the psu
Then the left
But which pins those 2 wires come from may be different for you where they come off the 6 pins
