- 26 Feb 2012
My MSI twin frozer iii 7950 stopped giving out signal after 3 months and I had it returned. MSI found a fault and gave the shop a credit note to send me a new one which I received today.
I have installed the new 7950, the fans are spinning but the card is not doing anything and is not being recognised in device manager when I use onboard VGA.
What is unusual about the replacement is that my old 7950 OC had 2 6 pin pci-e slots but this version has an 8 pin and a 6 pin pci-e. It also has V2 on it which suggests it is improved. Luckily I have a 6+2 pin connection I put in together.
When at first it did not show signal I downloaded the 12.7b driver which installed correctly but the graphics card still did not work. I went back to on board and device manager showed no card in PCI-E and there is nothing in the bios to suggest the card is in.
I have a 550w corsair vx550w psu which is more than enough.
Any ideas on what the problem could be?
