replacement case fan/side panel
18 Apr 2013
Hi there.
I have an xclio 3060 case and don't want to replace the whole thing.
Any of you who know this case or look it up will see it has a giant 360mm fan on the side panel. My problem is this stopped working years ago and having tried shopping around I'm being told xclio no longer produce them as they go wrong quickly.
So really what I think I'm looking for is a replacement side panel that will also help cool the system maybe with two fans on the side like I've seen on some cases which would probably perform better than the one 360mm fan I used to have. Don't mind if it supports 120 or 140mm fans. I know some side panels have 200mm fans also.
Any recommendations on how to get hold of something like this or which to purchase would be great. Do OC have replacement side panels? I can't see them if they do.
I do not think you fill find a replacement in any way, both as a side panel or just the fan. Seeing the case and how ancient it is, I would definitely go for something modern in the £50-80 range. Fractal Design Core 3000 is a great budget choice but there are quite a lot of cases that are worth the money in the range I have specified.
