Replacement case fans
22 Jul 2012
UK
I've got a Antec GX1200 GX Series Midi Tower, but the bundled case fans are a bit loud and I'm looking to replace them.
I'm a bit confused at the power connectors though - I've got an Antec High Current Gamer 520W '80 Plus Bronze' PSU.
Any recommendations re. quiet case fans which would match the case/PSU?
I'm not bothered about lighting effects, adaptive speeds etc - I'm happy to set the speeds manually and just leave the fans working. I'll probably have 2 or 3 blowing in from the front and 1 or 2 blowing out from the top.
Thanks in advance.
(EDIT - just to add to that, I know the case has a 'Magic Box' to control fan speed etc, but I've never been convinced that mine works properly. I'd much rather have a simple manual fan control)
You'll probably get more views and suggestions posting in the overclocking and cooling sub forum , post in there and include a rough price you wanna spend
