Currently running a Thermaltake Kandalf LCS plus sidepanel with the 200mm+ fan from the non-LCS Kandalf.
Anyway I'm looking for a replacement case as its been a big (hot, heavy and awkward to move) dissapointment since I bought it.
Ideally I need :-
1) Space for atleast 6 HDD, ideally something easy to remove and toolless.
2) Good for aircooling, I will initially be using air cooling (for which I need recommendations for my o/c i7 930) although a basic watercooling system is quite probable in the nearish future.
3) Good for a basic watercooling system.
4) Something with good cable organisation. Although few people beside me will ever glance inside the case I hate the rats nest most cases become either when 1st put together or after a couple of upgrades.
5) Ability to take long video card without havent to modify the case, remove half the fittings or having fingers cut to shreds while threading cables. Although I only have a puny HD4870 at the moment, dual GPU replacement is possible.
A quick look around led me to Corsair 700D/800D the major thing putting me off is the shear size, I'm used to full towers but both of these are 2.5inches and longer than my Kandalf!
And why the hell is there £60+ difference (aleast at OcUK) between the cases when the only real difference is a removeable front bay and a windowed side panel! Speaking of which is it cheaper to by a 700D and by a windowed panel seperately (I have heard you can buy them but haven seen them for sale anywhere).
Any recommendations?
Ideally I need :-
