Replacement Case Panel
15 Jan 2010
Scotland
Does anyone know where you can get a standard half height 5.25" case panel? The PC case that I'm using right now is a Mesh MAtrix 64 3000 FX. It originally came with a CD drive and a DVD drive, but I have bought a new DVD drive and would like to remove the two old ones from it. The problem is that it doesn't have a panel to cover up where the 2nd drive is, is there anywhere I could get another panel?
