Replacement case recommendations
18 Jan 2009
Well I bought a Coolmaster Cosmos S sport about 2 years ago and it seems, that over time its power button has started to fail which seems to be the cable that goes between the power supply and the m/b. Well i need something large as I hate small cases that are very easy to keep tidy as my idea of a tidy case will make you all shocked !
Cheers.
Im more interested in your idea of a tidy case :D, fractal design define xl seems to be a favorite around here, me personally would recommend something from Silverstone or lian li,
lian li
a tj07 from silverstone
and a wild card. these look very promising with lots of room, its pricy for a punt but read up on some reviews and it maye be the right case for you.
cubitek
