I haven't got an manually overclocked system as such, I have a Phenom II BE 560 which, by using the auto-unlock and "turbo" function on the motherboard, has made it four core and running at 216Mhz FSB/HT, meaning 4x 3.5Ghz.
The problem is it runs way too hot, and when using a video converter which puts all four cores at 100% the temperature shoots right up and causes a shutdown.
My current cooler is a Arctic Cooling Freezer 7 Pro Rev 2, I don't think this is up to the job, it needs regular de-dusting to keep the temperature within reasonable limits, can anyone recommend a not too expensive replacement that might suffice that would suit this CPU ?
I probably need to sort out the case airflow a bit as well, my current case is quite old and only has room for 80mm front and back.
