I noticed my cpu fan is barley turning causing my machine to lock up
I need a replacement fan or cooler if no fan is compatible.
This is the cooler I need the fan for
http://www.overclockers.co.uk/showproduct.php?prodid=HS-027-SY&tool=5
to fit this case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-222-SV
I tried order a new scythe but seems they are out of stock but with no eta on restock
I'm asking because the specs say 100mm fan on the cooler but I cant find one on ocuk that's 100mm
Also the cooler I have butts up to the graphics card, so just fits.
to fit this case
