Hi all,
I've been out of the scene for a while but have suddenly found myself having a lot more time on my hand! I've currently got a 3770K with a decent OC on it and a 1080 (non-Ti) under water in a Silverstone TJ-07. As the pump in the system is coming on 10 years old I know I'm probably playing with fire so I felt a change was needed. Also, the case is rather dated in features and worse for wear. I've put together the below list and was hoping someone could give it the once over just to see if there's anything I've overlooked or missed out. The reservoir I have currently is a bay mounted one, and in the new case that of course isn't an option and I currently have a quad rad that's the only rad in the loop.
Please let me know your thoughts and your suggestions are gratefully received. Budget is fairly flexible and the rest of my specs are as per my signature.
My basket at Overclockers UK:
- 1 x Phanteks Enthoo 719 Full Tower DRGB Case - Gunmetal Grey= £179.99
- 1 x Phanteks Glacier R220 RGB Reservoir - 200ml= £94.99
- 1 x EK Water Blocks EK-DDC 3.2 PWM (12V PWM pump)= £69.95
- 1 x EK Water Blocks EK-Duraclear Tubing 13/10 - Clear 3M= £13.99
- 12 x EK Water Blocks EK-Torque STC 10/13mm Soft Tubing Compression Fitting - Black= £6.95
- 1 x EK Water Blocks EK-AF Extender Rotary M-M G1/4 - Black= £4.99
- 1 x EK Water Blocks EK-AF Ball Valve (10mm) G1/4 - Black= £13.99
- 4 x Arctic Cooling P12 Black Case Fan - 120mm= £5.99
Total: £499.96 (includes shipping: £14.70)
