Replacement ds battery
28 Dec 2002
UK
Hi,
The battery in my ds lite is no longer holding charge. Does anyone know is genuine replacements are avaliable to buy? I have looked in some major high street stores, without luck. Need one for my holiday.
Cheers.
Haha, funny.
I've tried that, but I was hoping I could get a Genuine Nintendo Battery. All the ones that seem to come up on Google are made by 3rd parties. I don't want my DS to melt by using some dodgy battery.
Cheers
Chris
Im sure its a certain battery, theres no point buying a cheap battery , try and spend a good amount and it will last you longer in the future,
