Replacement element for passive sub enclosure.
1 Dec 2002
Swindon
I've got an Onkyo audio system which (for me) is good enough, however the Subwoofer has developed coil rub and needs changing..
Can you recommend a cheap replacement element (8 inch) I can stick into the same case? The existing sub is passive, so new sub will need to be the same.
