Replacement Fan for Armor+ MX
22 Sep 2010
Torbay
Hi,
Are there any silent 230mm fans for this case that anyone can recommend?
The PC is mostly silent apart from the huge fan on the side and I wouldn't mind replacing it with something much quieter.
I stream a lot of video and it's a bit annoying having a whirring sound coming from the other side of the room all the time.
I have this case, all I did was use the 5 volt mod on the fan.
It was still audible at 7 volts, but now its at 5 its probably the quietest fan in the case.
Plenty of guides out there to do this, basically all you need is a flat edged screwdriver to move the pins.
Of course it doesnt move nearly as much air anymore, but if all you want is a quieter pc then it makes sense.
