Replacement Fan for CoolIT Vantage?
30 Oct 2007
Hello.
After having some problems with my CPU cooling (temperatures would almost-instantly spike up 10-20°C as soon as I ran certain games, the latest being Battlefield 3 beta), I thought I would get a better fan to replace the stock one on my CoolIT Vantage ALC CPU cooler.
The stock fan is 4-pin, but the one I am looking at (and have seen recommended elsewhere) is the Scythe Gentle Typhoon, which is a 3-pin, but comes with a 4-pin adapter. What I want to know is will the CPU cooler still be able to regulate the fan speed on this 3-pin fan?
Depends on your motherboard and what software you use. My Gigabyte motherboard will control my 3 pin CPU fans but strangely not through it's own software so I use Speedfan.
The 4 pin adapter is a Molex adapter, not a 4 pin PWM connector.
The setup is fan - CPU cooler - motherboard. The motherboard doesn't really have much say in the running of the fan. It's controlled by the CPU cooler, by setting it up via the built-in LCD screen.
Ah right. Well, can anyone recommend a good 120mm fan, that has a 4-pin connector?
A lot of people recommend the Akasa Apache fan and by coincidence it has similar rotational speed to your linked Scythe GT fan. I don't think that the Apache is as good as the GT though.
Yes those are the ones. Fantastic fans. I've had apache's too but the vipers I find a touch better. If you want to run more than one fan off the cpu fan header you need one of these
The thing I am worried about is that if I don't run the fans through the CPU cooler, it will start having a fit at me because it'll think there are no fans running.
I just had a look at the way the Vantage is connected - There are 2 4-pin connectors coming from the CPU cooler - one goes into the motherboard, and the other connects the fan up, so the CPU cooler can regulate it.
I cannot think of an obvious way to connect a splitter that would allow the CPU cooler to moderate the fan speed on both fans.
Well, I bought one of the Vipers, plugged it into my CPU cooler, and the cooler wouldn't turn on. I don't know if the fan is drawing too much power or what.
So I've plugged the new Viper into a motherboard 4-pin socket, and fixed it to the radiator. I put the original CPU radiator fan on the other side, as the pull part of a push-pull setup. I also flipped the 200mm fan on the top of the case, so it blows air into the case rather than drawing it out.
I tried a stress test using Real Temp and Prim95, and got a max temp of 75°C.
I ran BF3 for about 15 minutes before I got bored, and my temp hovered around 65°C for quite a while, and maxed out at around 72°C shortly before I quit.
There is space on the case for a 80mm fan on the other side of the motherboard, which would blow air onto the back of where the CPU sits. Would it be worth putting a fan there, and if so, should I make it push or pull?
Also, there is another spot on top of the case, for a 120mm/200mm fan. Should I get one for there, and make it push or pull?
