I have a Tuniq 120 which sounds like an aircraft taking of on full power, although as far as cooling goes its superb.
Unfortunately with the stock fans CPU connector only being 3 pins and the header on the MoBo (680i) being 4pins I can not adjust the fan speed from the BIOS or with SpeedFan. I have attached the manual adjusting thingy that came with the Tuniq and it just plain and simple does not work.
I do not really want to take the whole machine apart and return the Tuniq as faulty due to the faulty adjusting thingy, so I was thinking could I get away with replacing the stock fan in the Tuniq with something quieter, with a 4pin connection so I can adjust the fan speed if required.
I had thought Akasa fans where the way to go but I could not find one with a 4pin connector that fits (I think its a 120mm fan I would need?) . So instead I was thinking of a Scythe S-Flex 1200RPM Ultra Quiet 120mm Fan 3/4 pins.
Any suggestions or comments, or better ideas before I order one would be cool...
