Hi, the fan clipped to my Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler has started making a rubbing/grinding bearing noise at all but the lowest speed. I contacted the manufacturer who said they don't have UK stock or distributor, and to look for suitable replacement, I tried but got a bit lost with all the details. This is the spec/model of the current fan https://www.titan-cd.com/en/product/TFD-9515M12ZP_KE_RB.html many thanks for any advice on what a suitable replacement would be. The PC is mostly used for music production so the main thing is low noise. Cheers!
