Replacement fan only for Ryzen 3600
5 Mar 2018
Hi,
Anyone know if it's possible to get a replacement fan only, rather than the whole heat sink unit, for stock Ryzen 3600?
I understand stock cooler is the Wraith 'Stealth' which caps out at 1900RPM. I'd like a bit higher RPM as temps are coming to 80+ under load which I know is within tolerance but would like to bring down if I could without spending too much as I'm not over locking and just casual gaming.
I think the 3600+ comes with the 'Spire' which has higher RPM but I don't want to buy and replace the whole unit if it is possible to just swap out the fan.
Cheers
See if you can pick up a cheap wraith prism cooler, I have one on my 3600 and it never goes above 67c with gaming at around 55c.
Get new cooler like Wraith Prism or any sub £20 92mm fan tower heatsink.
Chronically undersized cooler won't become better by changing noisier fan into it.
