it stopped spinning after working normally for a year. i took it out cleaned it and then it worked again but after second reboot same thing. i'm assuming it must be dead fan. i can't find replacement anywhere though
i took it out again replugged and now it spins again. its really strange i have no idea why it started behaving like this as it worked flawlessly for long time. maybe i won't need a new cooler after all.
I have used that very cooler myself in the past ...and also had the same issue with the fan stopping spinning here and there, and so I replaced the cooler .
i had issues with this cooler it stopped spinning the fan again. i did test so now it will spin on three pin connector but not on the four pin. why is that?
