Replacement fans for 600t.
16 Mar 2012
Hove
Ok so i only built my system last night, and they're on the fan headers atm and ive not looked at changing the cooling curves / havent got them plugged into fan controller due to wrong connectors right now.
I will try all that however just incase, what are some replacement case fans i can use that are a bit quieter? For the front 230mm / top 230mm and back.. 140mm? i don't mind using 2 in the top or anything like that, also im pretty sure im at negative air pressure atm, should i maybe leave the front going at full whack and controll the outakes?
Ill know more once my cpu cooler comes today, and ive switched from the stock and done a bit of testing on how loud each one is... Thanks
