I want to replace the noisy fans on my PowerColor RX580 but I am not sure which fans to go for. The stock ones are giving me a headache. Sounds like a jet taking off
A new card is out of the question for a few months so I need to reduce the racket this one makes for now. I have tried moderating the fan speed etc using the AMD software, which works for maybe 10 seconds and then the card seems to override the settings and the fans ramp up again. I will be stripping it down and replacing the old thermal paste which may help a little but I know these PowerColor RX580 cards are loud anyway.
Does anyone have any suggestions for which fans to go for?
A new card is out of the question for a few months so I need to reduce the racket this one makes for now. I have tried moderating the fan speed etc using the AMD software, which works for maybe 10 seconds and then the card seems to override the settings and the fans ramp up again. I will be stripping it down and replacing the old thermal paste which may help a little but I know these PowerColor RX580 cards are loud anyway.Does anyone have any suggestions for which fans to go for?
