I recently installed a new H100 in my system (5/6 months ago) - Over the last few days at least one of the fans on the res has started to sound really bad when it runs, annoying loud if i`m honest. I am currently running the system in a pull config with the fans mounted on the outside of the case and the res on the inside, this was to make it easier to just clean the inside of the res to get the dust off. Now, I know I should take my pc apart and give it a nice clean out from the inside but I think for the cost I should look to replace the fans on the H100 at the same time because I am sure one of them is defective. So, OCUK what are the best set of fans for this CPU cooler that you people recommend to use in a pull config?
Thanks,
Slade2
Thanks,
Slade2
