Replacement Fans for Xbox 360?
They are 60mm and in a custom housing. There are few replacement fans around, like the talismoon whisper, but even they seem to be a mixed bag with some claiming they are too loud and others saying they are great.
You can fit two separate 60mm fans in the space the old ones were in, but you'll have to modify the connectors to power them. I think you can squeeze 70mm, maybe 80mm if you trim the excess casing of them off.
Sounds like a challenge to me. I'll have a look inside and see what I can do. Thanks for the help :)
