Replacement for 8800GTS 320MB?
Permabanned
21 Apr 2008
AFter all these years my 8800GTS has given up the ghost.
Im now looking for a card to provide as good if not better performance without spending morethen 60 sheets
any suggestions
thanks for all the suggestions, is the 5750 worth it over the 60 quid 9800gt
I had a quick look for a comparison of a 5750 v a 9800gt on anandtech but the closest you can select to a 9800gt is the 8800gt. I don't think there would be a massive difference but I'd imagine 5750 would at worst be on par or edge it a little, perhaps more so at higher resolutions due to more memory. If you're going to get one then don't pay top whack for it.
