Having tried and failed to OC my E7300, I've decided to get a new CPU and board. Only trouble is, I dont really know much about cpu's and boards. I was looking at the i5's and AMD's PII quads. AMD's are cheaper and are quad cores but I've havent used a AMD cpu since I had a Hp pre-built. From what I've seen of the i5's is that they OC like mad.
Could someone spec me a cpu and board.
Budget is, as cheap as possible. Will be also buying a 5850 if that makes any difference.
