Replacement for a Fitbit Charge 4
29 Feb 2004
I have a Fitbit Charge 4, I was happy with it until Google bought Fitbit and decided to make everything worse. Before Google bought Fitbit, you could easily view the max heart rate you had during an exercise, now you can't. It only has the heart rate graph, so to see your max you have to flick through and try to catch the highest peak on it. When using the gps function, you used to be able to see your maximum speed, now you can't. If the gps drops, the only way to resync it on a charge 4 is to end the exercise and start a new one splitting your exercise in two. No problem before google, when you sync it, you would get two of the same. Since Google, it doesn't seem to hold both, if you do that, when you sync it, you lose the first half. App also randomly gets stuck syncing for no reason, never did that before Google. Since Google bought it, I've also had to remove it from fitbit and pair it again multiple times for various reasons, before Google bought Fitbit, I had never had to do that.
No idea why Google bought Fitbit and then decided to make the app/device worse, but they did. I've had it for over two years, so I think I will just replace it to get away from the trainwreck Google turned it into.
There's so much choice I'm a bit lost on where to go now. Use case is basically the same as the charge 4, so:
I use the GPS to map cycle rides with heart rate & speed. Not telling me where to go, but once you are done, the app puts it on a map. GPS is built in to the watch, although it can use the phone as well if you want. I want to be able easily view all stats (so max heart rate, max speed, average etc).
I use it for exercise in general, so select exercise, do it, end it, get all the stats for that session.
I have it on most of the time, so it tracks resting rate, sleep, oxygen etc (or so it claims).
I'm guessing the latter two most fitness watches do, the gps is the most important for me and has to be reliable. I don't use or care about smart features like controlling your phone, viewing messages, etc. Other thing I would like if possible, everything is online for the fitbit, you can't sync to the phone app if you offline, you can't view anything offline as it doesn't have any local storage. Being able to sync from watch to phone and view everything when offline would be nice if possible.
I have around £200, but if it's really worth it, I can put up with the charge 4 for a bit longer and save some more.
Thanks.
For me the Garmin gear out performs the fitbit stuff in every single way possible. They have a big range to suit all budgets from the simple activity tracking wristbands up to super technical watches costing a couple of grand. The app is superior too and integrates into other apps so much better such as Strava.
I've only had the Fenix range of watches which are overloaded with features but heard good things about the Forerunners which will likely land in your budget.
Thanks. Going to look into them a little more.
Forerunner 255 looks like it might be for me. Has new/better gps and seems like it does everything this fitbit does and more. Currently £259, but family member can get 10% off at maybe a competitor so can come down to £233, looks like the rainforest had it for £219 at one point as well, so will keep an eye there.
Sort of related and I'll look into more when I make a decision, but does the garmin stuff all play nice together? Like If I get watch, then get a bike specific gps at a later date, can they sync with each other so the bike gps does the mapping, but the watch gives it the heart rate? Not planning on getting anything other than the watch for now, so not a dealbreaker, but nice if they could.
Yep, seamless. The Garmin app is pretty decent too but they integrate with Strava very well which imo is superior to all other fitness / tracking apps.
If you select ride activity from your watch it will track GPS, speed, time, distance and HR anyway. The bike computer (like a Garmin Edge, I have the 520 plus) will track distance, GPS and speed metrics too except its easier to look at when riding fast. You can usually get them bundled with a BT HR chest strap with a decent $ saving which the bike comp will pick up so you dont even need to bring the watch. :)
Thanks. Will just be sticking with the watch to start with, but it all playing nice together is good.
Went from a fitbit to a Garmin and haven't looked back. Garmin app is sso much more in-depth. Makes the fitbit look like a kids toy tbh.
Thanks.
That settles it then. Will switch to Garmin as soon as the forerunner 255 goes back on sale (jumped to £299 in most places again). Might be a little overkill feature wise, but I want the new gps and can always just use the parts of it I need.
