My Radeon 7850 has just died. I'm also moving to a linux system, and I believe that nVidia has better support for that. I will most likely dual boot Windows for gaming if absolutely needed, but I mostly play Dota2 (which is supported on linux).
Any suggestions for a replacement? I'm currently looking at a 750Ti, which looks about the same performance wise as the 7850? Don't think that I really want to go above £150 unless needed.
Happy to consider any other suggestions.
