Replacement for antec Ar-350 psu
21 Jun 2022
Uk
Hi Folks.
I was hoping someone may have some advice. I was given a couple of pretty cool looking Antec sff shuttle type cases, Nsk-1380. They have a specific form factor PSU which is failing when I use a PSU tester on either of them. The PSU is an Antec Ar-350.
I was wondering if anyone knew the form factor of the PSU and was hoping for a suggestion for a replacement unit.
Many Thanks.
N
Wild stab in the dark suggestion. Replace it with a small form factor PSU but you may have to custom fit it. Antec may say that the existing PSU is proprietary like most of the big box pre-built PC's. I owned a similar case many years ago with a 'custom' PSU Aspire M-atx case. The PSU failed after a few months so it was RMA'd.
Thanks for the answer, I think that you are right - I will have to have to modify an existing PSU I fear, perhaps using a male female kettle lead.
