- 21 Sep 2003
I bought a Bitfenix Ronin back in 2014 (!) and, having recently upgraded my system, feel I should change my case for something with better airflow and less noise. My requirements are:
- Full tower (I don't want a midi or micro tower)
- Max budget £80-100
- Good airflow (I have an Arctic Freezer 34 CPU fan)
- Reasonably quiet
- Room for my MSI 2070 Super
I'm not bothered about RGB unless the other requirements are met.
What should I be looking at?
Edit: I've just had a quick look and there's basically no full towers anywhere near my price range - so I'd go for a midi, so long as it has a decent amount of room inside for easy installation.
- Reasonably quiet
