replacement for canon kit lens
Depends on if you want the extra reach and slightly wider end, but you'll be giving up the constant f/2.8 aperture and IS.
A couple of good options if you want something cheaper but still a good upgrade from the kit lens, are the Tamron 17-50mm non-VC, or the Sigma 17-50mm OS. I've used both and found the Tamron to be sharper (plus it's cheaper), but I dabble in a bit of video so the OS is really helpful.
I have the Tamron mentioned above and the Canon 17-85 IS.
Haven't had the Tamron very long but does seem nice and sharp. Wide aperture a bonus.
If the Canon was that good I wouldn't have looked at the Tamron. I've never really been that impressed with it.
Ben ,thanks but the lens were 17-55 or 15-85, the 17-85 has problems so I've heard and isn't on my list but interesting you also liked the Tam.
Hunders thanks for the rec,really hard to split the 2Canons .
Yeah, just thought I'd mention it. Not had problems as such, just never been that blown away by it.
The Tamron seems to get consistently good reviews for a budget lens though.
Oh yeah, the 15-85mm does have IS, sorry, forgot.
For me, constant f/2.8 is the more useful. I haven't found the need for the extra 55mm -> 85mm that I couldn't do just by taking a few steps forward. But your general situation might be different from mine.
For me because i feel 50 - 55 is a little short i would always go with either 15-85 or sigma 17-70 contemporary (f2.8-4), which is really versatile - wide aperture, close focus, IS etc at a very good price
I've owned the 17-55 previously and currently have the 15-85, although it's worth noting that the latter didn't replace the former.
Both are excellent lenses. If you really want or need the f/2.8 constant aperture then go for the 17-55 but otherwise I'd stick with the 15-85 as I think it's a better walkabout lens.
Yeah I think, on balance, the 15-85 has more going for it. It's better built, has better range and better IS. The image quality is excellent.
Well it's not f/5.6 across the entire range plus it's f/5 at 55mm, meaning at worst it's one and two-thirds stops slower than the 17-55.
As to how much this matters - that depends what you want to shoot. Indoors? - frankly f/2.8 barely cuts it indoors anyway, plus with static subjects the improved IS of the 15-85 will give you back what you lost to the 17-55 by aperture. Yes, with low-light conditions and a moving subject, f/2.8 is obviously better.
For me personally aperture is more important. I have the Tamron 17-50 f2.8 Non VC and recently bought the Canon 17-55 f.28 IS on this very forum. IS really is a revelation. Thinking of selling the Tamron actually.
Having said that, I'd be more excited by the 15-85's extra 2mm at the wide end than the extra 35 at the long...
I agree on the aperture personally - I have a 24-70 myself, but overall, for a single walkabout lens, I think the advantages of the 15-85 outweigh those of the 17-55, just! Others may have different priorities of course :)
As for IS, I can't say I've really missed it.
