16 Mar 2011 at 19:31 #1 DarkWhisper DarkWhisper Associate Joined 22 Aug 2009 Posts 717 Location Nottingham in need of a game pad with same under triggers as chillstream. any others out there as i cant get another one of these.....
17 Mar 2011 at 06:37 #3 DarkWhisper DarkWhisper Associate OP Joined 22 Aug 2009 Posts 717 Location Nottingham Do they have the under triggers
17 Mar 2011 at 06:43 #4 cjgardens cjgardens Soldato Joined 26 Aug 2010 Posts 3,302 I Googled that pad you said and it looks like a rip off of a xbox pad and yes it does and there great. Plug and play no messing
17 Mar 2011 at 07:08 #5 DarkWhisper DarkWhisper Associate OP Joined 22 Aug 2009 Posts 717 Location Nottingham Can i use a normal 360 pad or does it have to be for windows one?
17 Mar 2011 at 08:14 #6 cjgardens cjgardens Soldato Joined 26 Aug 2010 Posts 3,302 There all the same its just a con. You can use a wireless one but you need a dongle there about 12 quid
