Replacement (for) CRT
8 Nov 2002
Kent
I was interested in going TFT but Im not convinced that its right for me in its current state.
1) I dont need the space
2) This issue of monitor lag:
http://forums.anandtech.com/messageview.cfm?catid=31&threadid=1797465
I would rather wait until they have addressed this problem before I spend money on an LCD (bearing in mind my current CRT has been used from pentium 5 -133Mhz to nforce4 opteron), so I dont upgrade often.
3) The fact that firingsquad.com in their latest artical dont recommend TFT due to hardly any supporting blueray ect.
However I want to upgrade because my monitor has a "mains hum" which might not be a problem for some but its a serious issue I cant ignor any longer.
My current monitor is a Gateway vx700 17" and it uses Sony Trinitron CRT technology. Its specs are here:
http://support.gateway.com/s/MONITOR/z01017/z0101712.shtml
I have my eye on a Samsung SM793DF:
http://www.samsung.com/Products/Monitor/CRT_Flat/LE17KSBBQ.asp?page=Specifications
However I just read a certain site which has user reviews and there is like 200 views of people not one mentioning point 2). on a Samsung 930bf.
Undecided need convincing.
might be that
most lcds run at 60Hz, so that's the maximum speed of it's update ... 60 times a second.
a decent CRT will run at about 85-100Hz, i.e. more (85-100) updates per second.
so there will be a difference in response times, in favour of the crt.
I definitely noticed it's much harder to hit things in twitch shooters like UT2004 on an LCD versus a CRT. That was on a standard 19" too (SM913B), not a high res widesreen. I think the electronics used to process the image leads to a delay, so what you're seeing on the screen can be a little behind what's actually happenning in the game. Hence you miss.
I doubt this would significantly spoil your enjoyment of most single player FPS games though. Not for most people anyway.
Im going to buy a viewsonic vx922 its apparently the best that is available for response time as measured on an oscilliscope:
http://www.tftcentral.co.uk/panel_comparisons/gamers_choice_2.htm
I will be able to do side by side comparisons when I get it. If I dont like it Ill search for a decent 2nd hand crt.
