replacement for dead 7600GT 256mb
21 Sep 2007
So, my gfx decided to conk out and its not even a year old.
My rig is used mainly for gaming (WoW and BF2142) and the 7600GT handled them fine.
Looking to get at least the same power, or maybe a bit more.
Budget will be about £50~, needs to be PCI-E also.
tldr; what cards are the same spec as the 7600GT.
http://www.overclockers.co.uk/showp... GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
http://www.overclockers.co.uk/showp...MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
http://www.overclockers.co.uk/showp...VI/HDMI (PCI-Express) - Retail (4718462008859)
Now the cards above are nearly within your budget but for just a little more you could get so much more oomph than you'd be getting with one of the above cards with a few others I've selected that will be listed below.
When you look at the price differential you will see the reason of why it is a much better option to save a few more quid and get the better card.
http://www.overclockers.co.uk/showp...Dual DVI (PCI-Express) - Retail (GV-NX88T256H)
http://www.overclockers.co.uk/showp...3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
In this scenario I think it's best for you to stay with Nvidia. The 3850 without doubt would be a match for your 7600GT but the 8800GS for the same price is the better card (I think) and for £6 more the 8800GT 256MB is better. In fact I'm sure the 8800GS is better than the 256mb ATI card but weaker than the 512mb card.
something like a 3650 would proberbly do you quite nicely, there around £50 - £60 and have a fair bit more whack than a 7600GT i believe, plus they support DX10, shader model 4.0 and such
i'd say get a 3850 512mb... It's above budget, but it will give you the oomph to last and fare a bit better later down the line...
Not to mention they OC like beasts - Gurusan has one at 900/something... that is faster than an OCed 3870
Going from a 7600GT the 3650 DDR3 will be a massive upgrade. I'm pretty sure you'll be impressed.
Well, I don't need anything uber, so I'm settling with a 3650 512mb DDR3. Hope it lasts longer then the old card!!
Nice one :). You'll see a decent boost, likely in the x1950Pro area in performance.
When I see better cards that aren't miles away from the budget I always like to list them but with any of the top 3 you'd have been getting an improvement over your 7600GT anyway.
