Replacement for E6600 fan please.
27 Jul 2006
Huddersfield
My stock fan on my E6600 has finaly died. Can someone recomend a nice cheap replacement that i can just plug straight in without having to do anything odd with the motherboard.
Thanks in advance
Zero
does this one Cooler Master Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1156) just clip in like the stock cooler did.
Because of problems with my hands i cant take the mobo out.
Also what can i use to clean the old thermal paste of the chip.
thanks
thanks
Yes it will but you will need plenty of room round your case, to get your hands in. But i would go with the arctic cooling freezer 7 (top left of page!) Its better.
Woo computer works again. Said 28C in bios. Are there any good simple programs i can test temp with in windows?
Used "sticky stuff remover" to get rid of old thermal paste as I had read it was the same stuff that Akasa are selling (Tims fluid?)
I got the Arctic Freezer Pro 7, only bit that was a bit iffy was getting the fan back on.
Also I didnt want to screw it down too much, as im scared of snapping something. It seems fine and as i said the bios temp seemed reasonable. Im sure when someone points me to a piece of softwear i can test through windows the temp will have normalised.
Thanks for all the advice
