Replacement for HD5850
17 Feb 2015
Hi, my Sapphire HD5850 started intermittently making a grinding sound a couple of weeks ago. Now its all the time (as loud as a coffee grinder) and seem to be seeing missing textures in some of the games I play, along with flickering triangle shapes... I think it might be time to replace, but its been a long time since I made any changes to my PC so not sure about compatibility
Mobo - gigabyte EX58 UD5
Ram - 6Gb
CPU - Intel I7 920
I play a few MMOs and strategy like civ5 and running win7 64bit
What can I get that will be at least as good as my HD5850 and work with my setup which is 4ish years old
Would this be about the same performance wise?
And the r7/r9 work with my PCI express 2 mobo? Was worried that new gen meant new slot .... Not really kept up with hardware
Depending on the PSU that R9 290 would be best bang for buck, if you don't game that hard and you want something only slightly more powerful than your HD 5850 how about a second hand HD 7950?
How much of an upgrade would you like?
Because you can get cards faster than your 5850 for way way way under the prices of the cards being suggested so far.
Well my current card ran all the progs and games I use just fine.. I get 70-90 fps in rift and archeage and until it broke everything else I used worked great, I don't want top of the range bcos the entire system is like 4 years old but something that will run my games would be sufficient...
I've always gone the radeon route since my voodoo 5 blew up, so prefer that generally
You won't go wrong with many of them tbh. I'm quite partial to Gigabyte, but there are many others that will more than suffice. Depending on how often you upgrade (which I gather isn't too often), you could base your decision on the length of warranty, like 3 years over 2. I usually upgrade every couple of years, so I always bear that in mind when considering a purchase. :)
