- 16 Aug 2013
Hello,
I am looking to build myself a new gaming rig from scratch. The main priorities will be gaming (Simming) and photo editing (large files!). I am planning on running crossfire / SLI GPU arrangement in an aircooled rig, with closed loop water for the processor - with output to a 1440 monitor
Currently, I have an i5 2500k which is in a closed loop water cooled system, but I have found it to be a bit uncomfortable on large files and on gaming using crossfired 7950.
So, it is time for a total rebuild. And this is where I get stuck - It has been a while since I built a rig, having had this processor for about 3-4 years (never overclocked, cos PSu not powerful enough to run o/c and cards :S) The interwebs is filled with opinions as to which processor is better, and it has got me completely confused - thought I would come here, cos you guys have been epic at recommendations in the past for me!
Really could do with recommendations for a new CPU on which to build my system. No parts will be carried across, so I have free reign on mobo, PSu, memory etc.
I must admit to being a bit uncertain as to whether to go for an i7 on the X99 platform, or see if I can find a i7 on the older platform, or indeed, any other choices - SO MANY CHOICES!!!
Any advice recommendations would be gratefully welcomed!!
Thanks, like, huge thanks - cos lost!!
) That is the main reason for upgrading , really. I am looking to run a pair of 970 or similar (not decided on that yet either)- so I need new case, a new PSU to support those cards, and well, once I get those, might as well upgrade the whole lot and sell off the old components cos they good and shiny for someone running at 1080
