replacement for my aging 480 please
14 Feb 2011
I'm looking to replace my 480 gtx with something a little more up to date. The only games I play are bf4 and Eve online. Budget about £200 if possible. And how much better will it be to an old 480?
Also I'm looking to finally upgrade to ssd, is my good olé sandybridge i5 2500k based system up to a minimal upgrade like these?
Thanks
think youl have up ur budget a bit more,unless you pick up a 7950ect from MM/otherwise id suggest a 280 to get a improvement over ur 480
GTX 760 for £200, though its not that much faster than your 480, about 20%
Really what i would recommend are GTX 770 or R9 280X, about 40% faster, but at ~£300.
£200 and a 480 to replace is a difficult one.
