- 4 Nov 2005
I've finally had it with my P180. There are some clever ideas, but it's a mare to work on, and after a year, both side panels keep falling off due to broken plastic connections (can't think of the right word), and the flimsy door is a disaster. I can't open it now without it falling off.
So I am looking for a case with the same cooling capabilities, but properly built.
Must Haves:
* 120mm fans front and rear. Not bothered about the top.
* Castors
* Access to power on and reset buttons, and at least 2 USBs without having to open the door.
* Black
* Roomy - that new HIS X1900XT of mine is a beast
* Well built!
Nice to Haves:
* Slide out Mobo capability
* Slide out front drive cages
* Thumbscrews not screwdriver screws
* Windowed side panel
* Anything that will help dampen Hard Drive noise - now the noisiest thing in my case.
Not bothered about
* Flash looks and curves - in fact I prefer minimalist.
* Locks - in fact no lock would be a plus.
Target price - around £100 inc VAT.
I have one or two suspects, but I will keep them to myself so as not to predujice your ideas!
As ever, hope you lot can help.
Must Haves:
* Castors
* Black
* Well built!
Nice to Haves:
Not bothered about
), if i wanted to be more flash i'd probably go for a Thermaltake VA8003BWS! 250mm side fan!!!
