Replacement for my XFi
23 Nov 2005
Kingdom Of Fife
Guys I am still on Windows XP but I must say over the past year I have been less than impressed with my XFi fatal1ty Pro. The driver support from Creative is sh*te to say the least. I am contemplating an ASUS Xonar D2 (I take it the D2X is PCI-e) what would you guys recommend? PCI-e or the PCI model? Is it worth the ton twenty for the upgrade?
You could also save yourself some more moneys by going for the DX.
I'm not sure what the major differences are, the only ones I know of is that the DX doesn't have DTS decoding, EMI shield, lights at the audio jacks and it doesn't have a seperate optical port, it's built into the lineout.
All comes down to what you need, all of the Xonars have identical audio quality according to some reviews I read though.
The question ultimately is guys is it worth upgrading from my X-Fi fatal1ty to the Xonar or Xonar D2 on WinXP Pro?
