Replacement for Razer Exactmat
Don
18 Oct 2002
Wargrave, UK
I currently use a Razer Exactmat with both speed and control surfaces. I use the speed surface most of the time.
Unfortunately, the surface has worn out after 5 long years of service but Razer don't seem to make them any more.
I would like a replacement with the same surface as the Speed surface on my Exactmat but I see Razer do tons of different types of surface. Does anyone with experience of these mats have any idea which current Razer mat most closely matches my exactmat?
u can still get them if you google, very nice mat and I still have mine in the drawer
I have just moved to a boogiebug aimb xl, its massive but v nice to use, I only changed due to new desk, its nothing like the exact mat so not really a like for like swap or recommendation
look at solid mats on ocuk, am sure there will be plenty of recommendations on here, nothing seems to match the exactmat tho... good luck
Five years out of you mat is impressive! Razer have a new double sided mat out called the Vespula. Looks like it's the successor to the Exactmat. Alternatively you might look into the Destructor. Use this mat myself and it is excellent. Doesn't come with a wrist rest though, but you have the one that came with the Exactmat.
