Replacement garden gate width
18 Oct 2002
I need to replace my garden gate as it's falling to bits. It seems the standard width of a garden gate is 900mm, however mine appears to be 890mm. Attached to the side of the house is a piece of 4x2" wood running vertically and the hinges are attached to a post separating my house with the neighbours next door.
The garden gate is 900m wide which is exactly the width of the space between both posts. It doesn't leave me any room nor does it allow for the wood expanding etc.
This is the gate I'm looking at: http://www.wickes.co.uk/Wickes-Pressure-Treated-Curved-Top-Gate-1800-x-900mm/p/137212
Obviously I'm not going to starting hacking the gate to bits so are there any tips to allow me to install this standard size gate?
Doesn't show in the pics where the horizontal pieces and braces on the back come to. It's normal for there to be a little planing space on each side
Take the existing bit of wood off and attach a thinner bit?
This did seem the best solution but I'm sure when I got a quote for fencing and asked them to do the gate at the same time they said it's best not to disturb that post attached to the brick. If I could avoid it then I would prefer to but I can't see that I have many options!
I guess it depends on what tools you have available.
Trimming either side of the gate with a plane would work (if rather slowly), but I'd run a circular saw or even a router down each edge to trim it quickly.
Personally I would take the post off, fill the holes in the brick, then drill holes for the new thinner post in different locations on the wall. Not really a difficult job (if you have a drill and a good masonry drill bit)
Ten minutes work when I did mine.
